Home > In Car Electronics (L322) > Tv upgrade and android
Jimes256
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Good morning. Is there a digi tv upgrade for my 2002 with fac nav? Failing that as I’d like Bluetooth also, what are your recommendations for android head units? Thanks
Post #588102 20th Mar 2021 9:01am
loads of stuff on this, have a search... Thumbs Up ... - .- -.
Post #588104 20th Mar 2021 9:04am
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
Best I can advise is reading this Site. I-Bus App and Ressler Interface together with a Xtrons Headunit is what I had in my 2004 FF. Before that I was for more than one year on a try and error dead-end road.
https://ibus-app.de/index_en.html
Post #588107 20th Mar 2021 9:16am
mjdronfield
Or you can stay factory and fit a BMW hybrid tv unit from a slightly later BMW, and your tv will then work.
Again, from a BMW, fit a ULF module and get Bluetooth phone connectivity. It won’t play music from your phone unless you have a lead to the BM54 unit in the boot, but you would make calls etc from steering wheel. All like factory. BMW did it on the system but they sold Land Rover by then, so RR never got it.
Or there are companies that will fit the options to your existing units in the boot, again, all factory.
That won’t however give you a higher res screen etc, like an android unit would, and all the newer options it has etc.
So depends which route you prefer.
I put the BMW units in my TD6 when I had it, and sold them on to people on this forum when I sold the car.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #588118 20th Mar 2021 10:31am
mjdronfield
http://www.carphonics.co.uk/
And if you like your music, the amp upgrade is brilliant.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #588120 20th Mar 2021 10:34am
Jimes256
Mjdronfield. Thanks. What units should I search for. It’s an occasional/hobby vehicle so I can’t really be bothered with the android unit. Yet!
Post #588131 20th Mar 2021 11:23am
mjdronfield
These are the tv modules.... straight swap...
https://www.ebay.co.uk/itm/BMW-3-X5-X3-Z4-...SwFn9fWMMP
https://www.ebay.co.uk/itm/E46-E53-E83-E85...SwHqVgEJl1
BMW ULF module....
There are loads of info on this forum about the ULF if you search. You will need to repin a connector in the rear of the car, and need a Bluetooth antenna and a microphone.
It needs to look like the below. Seems the later you can get the better. If it says MIT SES on the label, it will also give you voice command option, over the cars info system, not just the phone. There is one with that on eBay but it’s in Lithuania....
Here is one without voice
https://www.ebay.co.uk/itm/BMW-E46-E39-E83...Sw8Wlf11lE
Antenna.... you will need to check your car to see if the cables are there already. Do a search on here, as it’s been covered a few times. Don’t really want to repeat it all.
https://www.ebay.co.uk/itm/BMW-X5-Telephon...SwePdfxQul
Some BMW upgrade options here too....
https://www.fullfatrr.com/forum/topic9811....w+upgrades
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #588134 20th Mar 2021 12:28pm
RRlincs
Where do the TV modules plug into?
Post #588531 23rd Mar 2021 2:04pm
RRlincs
Post #588532 23rd Mar 2021 2:04pm
mjdronfield
You should have one already, in the left hand compartment in the boot.
The original one is analog only though, so of course won’t work now.
Existing unit in the car will look exactly the same.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #588536 23rd Mar 2021 2:13pm
RRlincs
Thanks, found it,
Post #588540 23rd Mar 2021 2:24pm
mjdronfield
What car you got mate? Fill in your car profile when you get chance.
The modules linked will only fit the earlier non touch screen cars, running the BMW infotainment system, but you prob realised that.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #588541 23rd Mar 2021 2:27pm
RRlincs
2004 TD6 Vogue with non touch screen radio etc
Post #588596 23rd Mar 2021 9:16pm
mjdronfield
Cool. Sorted then. I kept my old unit and put it back in when I traded the car. Sold the hybrid tv unit on.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #588608 23rd Mar 2021 9:57pm
