![]() | Home > Maintenance & Mods (L322) > Brakes: excessive travel and sponginess - any advice please? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8700 ![]() ![]() ![]() |
My old 2002 would let you press the pedal to the floor if you sit with moderate pressure on the pedal, it was like it the entire time I owned it but did not effect the breaking at all... I think they are just like that..!!
MarcoPolo Member Since: 07 Dec 2018 Location: Preston Posts: 19 ![]() ![]() ![]() |
Many thanks Pete. That's very helpful, and it's good to know that there is/was at least one other like mine! The mechanic suggested that because the vacuum had been significantly increased by replacing the non-return valve, the brakes would have a very different feel to them, which in light of your own experiences seems reasonable. I'll also check out the callipers as you suggested. Thank you again. MP |
LROMAD Member Since: 10 Oct 2015 Location: Cheshire Posts: 54 ![]() ![]() ![]() |
Hi Marco ,did you resolve your problem with your brakes? I'm having very similar symptoms,with my 2008 tdv8.Any information would be v helpful. Thanks ,LROMAD |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
I’ve just replaced my front disc, pads, calipers and bleed the brakes, before the brakes took a little bit of travel before they felt like they would apply.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Thats leaking master cylinder seals that causes that and you should be thankful you never did long descents requiring braking for an extended time with moderate pressure. It would definately had an effect on braking performance then ![]() 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
There would be a different feel is so much that little pedal pressure is needed to achive good braking performance, if the pedal pressure is the same but the travel is excessive, try clamping the flexible hoses in turn until you find one that reduces the pedal travel, you then found the guilty party that needs more bleeding, or bleed some more using a pressure bleed device. Pedal travel = air in the system or fluid going somewhere. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
