Home > Technical (L322) > Engine System Fault message
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
(thread title edited by RRUK)
My tdv8 is telling me "engine system fault" an the boOk says it's serious !
The warning is only on tick over, no loss of power and no smoke. To be fair it was slightly slow to pick up off a roundabout! Amy ideas ? 2007 TDV8 Vogue SE
Post #63287 10th May 2011 11:03am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Get it plugged in, it'll save all the guess work Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #63289 10th May 2011 11:18am
David
Can most garages plug it in or does it need to be a main dealer/specialist ?
Thing is both the above are a bit thin on the ground over ere ! 2007 TDV8 Vogue SE
Post #63294 10th May 2011 1:08pm
David
just spoke to a garage who said it could be something a simple as " Censored FULE " ???? 2007 TDV8 Vogue SE
Post #63295 10th May 2011 1:14pm
pretlove
do you mean fuel "RANGEISM WILL NOT BE TOLERATED"
Post #63313 10th May 2011 6:47pm
elpeede
Some of the faults will be able to be picked up by EOBD kit but any of the modules beyond that will miss info.
I'd hazard a guess that if its thrown up a light on the dash its likely the EOBD would give at least a fault code to work from so its work a punt. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #63353 10th May 2011 11:59pm
David
Its not throwning on any lights, just a warning message.
Had it pluged in and no fault codes stored, on a live run test its saying low pressure to actuator. Car seams fiine when reving so im hopeing its split pipe. Anyone else had it ? 2007 TDV8 Vogue SE
Post #63377 11th May 2011 9:23am
David
Really looking fr help now !
Car in at landrover and they say they cant find anything wrong but they agree it is giving a live message and is deffo down on power at low revs but only when accelerating like when over taking. It's fine from the lights and at high revs 2007 TDV8 Vogue SE
Post #63470 11th May 2011 7:16pm
if the cars in landrover and they have done the checks and cant find anything then its going to be very difficult for someone here to find a solution.. ... - .- -.
Post #63473 11th May 2011 7:30pm
David
You ain't seen landrover spain 2007 TDV8 Vogue SE
Post #63484 11th May 2011 8:13pm
Laughing maybe you'll have better luck reading through some of the threads here then. Thumbs Up . ... - .- -.
Post #63506 11th May 2011 9:55pm
David
If I had of done I wouldn't of posted this
Would I . Can find anything relating to the problem as mentioned above. 2007 TDV8 Vogue SE
Post #63541 12th May 2011 8:43am
as mentioned above, you need a fault code to identify the problem otherwise its just guesswork... ... - .- -.
Post #63544 12th May 2011 8:58am
David
As stated there is no fault code in the ecu, i had it checked again last night from an non land rover garage. there is no fault code and no light on dash just the warning message. There is a live test error saying low pressure to actuator. 2007 TDV8 Vogue SE
Post #63557 12th May 2011 9:51am
i'm confused now, so this is the answer to your problem then..
Post #63580 12th May 2011 12:48pm
