![]() | Home > My Range Rover > New Wheels for me too! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Once the new wheels are here and fitted and I've had chance to give mine a thorough spruce up (it's not like they're in bad nick as it is) I shall put them on the forum and PM you. As a taster, they are the later model 20" wheels with the dimples (from a 2007 car), TPMS valves fitted (and working) and each tyre is identical, all Pirelli Scorpions, all with 4mm of tread, never repaired or punctured, no damage. The wheels are fully balanced (a MAJOR bugbear of mine) and simply ready to fit. Will they fit your car? Think you may need newer nuts ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Great stuff |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
them new wheels are nice but the ones you have now are my favourite range rover wheel. 2004 black Vogue TD6 |
Very nice Adam , Yep funnily enough i still have those Alloys , good choice tho |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
+1 ![]() mike |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
nice wheels i think i prefer the ones you have but then i would say that as i have the same ones but without the dimples...still a change is good |
well go fit them then............ |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
Adam, is there any difference in the offset between the two styles? As I have also changed different style wheels and found that some have 57mm, 58mm, 60mm and 53mm - the ones I fitted had more off set 58mm so sunk in under the arches which was somewhat annoying! 4 or 5mm didn't seem much but I noticed it. |
I have NO idea!
on the back / inside, usually it says something like 19 x 8j x 53et
Vogue,
Hi Adam, no, some of the 20" FFRR wheels have a 53 mm off set (the same as the RRS) whereas other FFRR 20" have 57 or 58 mm off set (which goes slightly further into the arch - from what I can gather these are the earlier styles).
On the back of these it says
