![]() | Home > Technical (L322) > battery drain & HVAC panel |
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
I imagine you are aware of this:
aterkut Member Since: 27 Nov 2020 Location: Eskisehir Posts: 11 ![]() ![]() ![]() |
I havent mentioned about that PROG button - I am talking about middle knob when you press it and it auotmaticly adjusts fan spped and vent mode... |
I wasn't trying to tell you which button you were talking about. I was merely pointing out one way the HVAC system may stay active.
got it - the best is to take action and try |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 149 ![]() ![]() ![]() |
If you want install this "XXX minutes delay relay", then why don't just connect it to the little fan behind the HVAC dash? No worries about losing settings.
hvac panel is full of 2008 model technology elecrtronics and I didnt want to touch that piece - just want to shut off it |
