Home > Maintenance & Mods (L322) > Steering Wheel upgrade
Page 5 of 7 <1234567>
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Daveo, the paddles just slot in exactly the same way the back spoke covers do. In my general gallery on disco3 there is a diagram but no picture (sorry). By the way, if you remove the steering wheel then unscrew the little torx screw from the front of the wheel, then u just pull hard on the back spoke cover from the direction of the wheel hub centre, and they pull off really easy without breaking. Had mine in and out a few times when I was fitting the paddles.
Hope this makes any sense at all Wink
And enough South African comments, you lot
Post #64447 18th May 2011 2:31am
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Steering wheel has just arrived and looks great. Hoping to get some time to fit it later. The instructions talk about knowing the cars radio code before disconnecting the battery. Any ideas where I would find it and has anyone experienced needed it when changing their steering wheel?
Thanks
Greg FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #64498 18th May 2011 1:31pm
dan_uk_1984
Thanks
Greg
We dont have radio codes - we do have a security code, but unless you enter this every morning you don't have to worry.
My wheel came with a hook tool, but that was wrong, it should have been a long thin tool. When I double checked, my instructions were from a RRS.
D
Post #64499 18th May 2011 1:34pm
GregP
Thanks Dan
The instructions I have appear to be right and have the straight tool you should have recieved. Have you fitted your new wheel? FFRR TD6 HSE
Post #64502 18th May 2011 1:38pm
dan_uk_1984
I have, it's lurvely! I wash my hands every time before I get into the car!
Post #64503 18th May 2011 1:39pm
GregP
Laughing
good good. You find it easy enough to fit? FFRR TD6 HSE
Post #64504 18th May 2011 1:41pm
dan_uk_1984
After 10 minutes of poking about with this hook thing it didnt take too long at all. It helps to have the new wheel to look at for reference.
Post #64505 18th May 2011 1:50pm
GregP
Ok, I'll aim to get it sorted later.
Here are a few pics
 FFRR TD6 HSE
Post #64511 18th May 2011 2:24pm
GregP
Fitted!!! Thumbs Up
Took some time to get the airbag off and the bolt holding the steering wheel in place was done up pretty tight.
Also had "air sus inactive" come up after re connecting battery but full lock both ways sorted that out.
 FFRR TD6 HSE
Post #64516 18th May 2011 3:45pm
bad news greg, its not straight... Very Happy
Post #64517 18th May 2011 3:47pm
GregP
Rolling with laughter I thought there was something wrong!! FFRR TD6 HSE
Post #64518 18th May 2011 3:51pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Looks great Greg Thumbs Up
Post #64535 18th May 2011 6:38pm
pretlove
greg it looks the dogs do-dahs i love the fact that even the spokes are leather Thumbs Up also i toke the plunge on that arm rest so ill let you know how good it is when it turns up Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #64560 18th May 2011 7:59pm
dan_uk_1984
I think mine's a bit boring now!
Wheel in context:
IMG_4867 by d86cfv, on Flickr
IMG_4869 by d86cfv, on Flickr
IMG_4862 by d86cfv, on Flickr
Post #64562 18th May 2011 8:11pm
GregP
Cheers lads. Just the black leather dash now and the interior will be sorted.
Fingers crossed on the arm rest mate, if it's good I'll be getting one as well. FFRR TD6 HSE
Post #64563 18th May 2011 8:14pm
