Home > Maintenance & Mods (L322) > Running boards
Teaspoonasaurous
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
Running boards
HI,
The rear portion of my running board collapsed under my weight the other day. it seems that it had filled with water and corroded!
The supporting struts to attach it to the car are still in place and seem sturcy. Can i replace just the boards without removing the struts, and where can I get some decent running boards
Car's an 02 vogue td6
Post #586698 8th Mar 2021 3:37pm
most aftermarket boards [ebay] are patterned on the genuine landrover ones so in theory they should be a straight swop...i would anticipate some fettling though.. ... - .- -.
Post #586702 8th Mar 2021 4:13pm
mjdronfield
You need to do a search for Side Steps to get tons of info.
A recent thread here.
https://www.fullfatrr.com/forum/topic58631.html
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #586703 8th Mar 2021 4:13pm
Teaspoonasaurous
Perfect thanks. £300 is steep!
Post #586705 8th Mar 2021 4:51pm
mjdronfield
Good job you don’t want the genuine Land Rover ones then.
£626 factory option
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #586706 8th Mar 2021 5:06pm
mjdronfield
Or £986 if you want factory ones to fit yourself.....
Don’t buy the cheapest.... but then there is no need to go mad 🤣
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #586707 8th Mar 2021 5:10pm
t5pete
I fitted a set of pattern ones to mine I'm sure they were around £170.00.
They are not exactly the same as the original ones where the silver strip around the edge is darker and plastic also they take some time squaring up with alignment, but other than that they are perfectly fine.
I undersealed the new ones to help prolong the life span.
Post #586720 8th Mar 2021 8:00pm
uzp315
I bet it is the near side board that collapsed?
I have OEM on my 2007. My near side collapsed a couple of weeks ago. After ringing around a lot of places to try and find a replacement, I was advised to speak to"Side Steps UK". I checked the website and got on the phone to them. They agreed to just sell me the one side I needed. It matched the original pretty closely. See my post on it, with pics.
£150, old removed, new fitted all done in about 15 minutes, in the West Mids.
Post #586800 9th Mar 2021 5:13pm
uzp315
Here: https://www.fullfatrr.com/forum/topic58631.html
Post #586802 9th Mar 2021 5:14pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I bought these recently and fitted them last weekend.
https://www.ebay.co.uk/itm/Alu-Trittbrette...2454918079
Personally am very pleased with them.
Had previously bought the aftermarket Range Rover style side steps, but was disappointed in the poor quality and plastic edging and never fitted them.
These steps are solid aluminium apart from the two sturdy end caps. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #586894 10th Mar 2021 8:04am
Teaspoonasaurous
Got this done just in time for MOT. Still failed the MOT quite miserably due to corrosion on the suspension. I'm waiting on the full report.
Big Cry
Post #589648 31st Mar 2021 11:58am
