Home > Technical (L322) > Air suspension lowering on its own... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
normally happens after you have jacked it up...take for a run and it should level itself.... ... - .- -.
5th Mar 2021 2:04pm |
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 |
Thanks Stan, the brake caliper I have been waiting for has just arrived! Car should be back on the road soon, I will post again when it is reassembled and I have taken it out for a drive. |
5th Mar 2021 2:19pm |
All back to normal.
6th Mar 2021 8:15pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8239 |
If you want to stop it next time, leave a door open, the interior lights will go off after around 15mins and the suspension will not try to level and lower each corner which is what happened to you... Pete
6th Mar 2021 10:34pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
With a door open press the light switch on the overhead console to turn off the interior lights. John
7th Mar 2021 8:10am |
