Home > Maintenance & Mods (L322) > Lower tailgate not closing properly. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7815 |
Spray a bit of lubricant over the latches on the tailgate, and make sure that the 2 plastic manual release levers both move freely.
2nd Mar 2021 7:37pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8625 |
As Mark says, can you hear the solenoid moving back and forwards when you press the button.
2nd Mar 2021 8:18pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
You can operate the latches using a screwdriver whilst spraying wd40 all over them. This usually gets them working again. |
2nd Mar 2021 8:34pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 442 |
The two plastic manual release levers (one on each catch) need pulling outwards away from the boot. The lower tailgate should then lock. This is quite a common issue when dust gets into the latches, which is why IMHO it's best to use something light like WD40 to lubricate them rather than tacky spray grease, which might be used for other locks / hinges. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
2nd Mar 2021 8:56pm |
Steve.W Member Since: 02 Mar 2021 Location: Essex Posts: 4 |
Thanks for the reply, will try this tomorrow and will let you know how I get on, and yes when I press the button I can hear the solenoid working. |
2nd Mar 2021 9:27pm |
Done as you said and has done the trick, works perfect.
3rd Mar 2021 8:21pm |
No worries. Should be good for a while now.
3rd Mar 2021 8:27pm |
Glad you got it sorted 1992 RR Classic 3.9 efi Vogue
4th Mar 2021 10:40am |
