![]() | Home > Maintenance & Mods (L322) > Why only drives side has air deflector? |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 ![]() ![]() ![]() |
Hi everyone,
Why not fit it to both sides? It's not like that one piece of plastic would cost to much to install one more. Thanks! Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
I have often wondered the same. The conclusion I reached is that it is less important for the passenger to see out the front! |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1278 ![]() ![]() ![]() |
And if you want to change the wiper clip on the drivers side you have to buy the whole arm because the clip is built into the spoiler. £80 a pop!! Passenger side uses normal cheapo clip. |
Kevinp,
Hi Larry. I bought 2 clips. Passenger side no problem. Drivers side is moulded into the spoiler. You could use the new clip without the spoiler but the blade would not then have the blade supports that are part of the spoiler. I will try and take a photo to show what I mean. |
