Home > Maintenance & Mods (L322) > Oil Level check
Jayk69
Oil Level check
Am i doing something wrong here?
i thought if you wanted to check oil level and it says "Not Available" if you clicked the cruise cancel button twice within a second it will let you check?
it is a real pain to have to wait 10 mins before a re-check Shocked 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #584463 19th Feb 2021 4:21pm
Baltic Blue
NB...The bonnet lid has to be open for the quick reset to work.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #584464 19th Feb 2021 4:24pm
Jayk69
ok never tried with it open as it have never worked with it closed..... Bow down
will try now thanks for that 2012 Vogue 4.4 TDV8 - Current
Post #584465 19th Feb 2021 4:25pm
JCW
Does the delay after stopping the engine not allow the oil level to settle giving a more accurate reading though?
Post #584466 19th Feb 2021 4:27pm
Jayk69
worked like a charm.
the reason is i added just shy of 9l of oil (my 11 year old was filling bless her) and cold it was on max. so i started the car let it settle and it was still max. I wanted it to be 3/4 to allow for it hitting max temp. so i pumped some out and wanted to quickly check. i only took less that 1/4 L out to get the desired level.
so handy tip from Baltic there Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #584471 19th Feb 2021 4:45pm
Baltic Blue
Thumbs Up Rolling with laughter
Been there done that Rolling with laughter
Post #584475 19th Feb 2021 4:53pm
DrRob
I start with 8.25L then top up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #584486 19th Feb 2021 5:35pm
