Home > Maintenance & Mods (L322) > Rear screen washer pump
Cavalier
2011 Range Rover Vogue 4.4 V8 Orkney Grey
Am I right in thinking, that the pump for the rear screen wash on a 2011 Vogue, is one of 3 attached to the water bottle situated behind the near side front wheel arch? I am getting no fluid at the rear screen. I have disconnected the fluid pipe at the join in front of the non return valve, pressed the washer leaver forward, no fluid plus I don’t think I can’t hear a pump running, I must admit I was listening at the rear of the car and Now think maybe the pump is down the front end. The rear wiper works fine.
Post #584458 19th Feb 2021 3:52pm
dingg1
You're correct 👍
Post #584460 19th Feb 2021 4:08pm
Baltic Blue
Number 6 in diagram
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #584462 19th Feb 2021 4:16pm
