Home > Technical (L322) > DPF Filter Full - Again....straight to Red |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4289 |
You either have an intake leak e,g a split hose or you’re not doing enough long journeys to burn off the soot in the DPF.
15th Feb 2021 7:15pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3118 |
wot Dr Rob sed. I had exactly the same symptoms as you and it was a pax side inlet manifold crack (minute, hard to see). LR supposedly changed the specs for later models (mine is 2011) and made it thicker and more able to resist flexing.
15th Feb 2021 10:33pm |
Tintin1979 Member Since: 15 Feb 2021 Location: London Posts: 2 |
Amazing! thanks so much for your help! I am in Sandwich, Kent and will get it checked out professionally rather than trying to do it myself with a diagnostic tool. |
16th Feb 2021 10:26am |
