Home > Maintenance & Mods (L322) > range rover td6 niose
iowdave
United Kingdom 2004 Range Rover HSE Td6 Epsom Green
hello to all this is a first post and a difficult one...i have a 2003 td6 the problem i have is when i accelerate i get like a rough exhaust niose from the front which sounds like the exhaust is split but its not it dont do it all the time but it makes the car to niosey inside drives me mad.. i have been reading on here.. could it be the waste gate valve on the turbo?..thanks for reading and i would very much appreciate any help thank you
Post #62463 3rd May 2011 7:47am
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
Had something similar in mine before turned out to be some cheap gasket might have been intlet manifold gasket will check recipts when back at home.
http://gallery.me.com/paul_harland/100010
Range Rover Vogue TD6 2002 "52"
Bonatti Grey
Post #62471 3rd May 2011 8:42am
iowdave
hi paul thx for the reply id appreciate it if you would .
Post #62472 3rd May 2011 9:05am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
If it has only started recently it could be the viscous fan spinning?
It is more noticeable in warm weather
Post #62477 3rd May 2011 10:42am
has you mpg gone down recentely?..it could be a hole in the turbo cooler which is under the radiator .. ... - .- -.
Post #62478 3rd May 2011 11:03am
iowdave
hi and thx for the replys its been doing it for a while now but it sounds exhaust. as i hear it from the drivers side it sounds like at me feet sometimes i can throttle and nothing other times like being in a tin can.
Post #62481 3rd May 2011 11:26am
if the exhaust 'cat' is under where you say then it could be broken inside causing the noise ... ... - .- -.
Post #62482 3rd May 2011 11:30am
iowdave
ok thanks il start looking there..id just like to say thanks very much for all the replys i will post the results once i have cured this problem
Post #62506 3rd May 2011 5:30pm
Thumbs Up ... - .- -.
Post #62508 3rd May 2011 5:36pm
oodathort
Im interested as i have a similar noise thats only there from cold for about 10mins then gone its like an exsaust blow
Post #62525 3rd May 2011 6:49pm
iowdave
yep no problem i will forward any progress i make...
Post #62540 3rd May 2011 7:48pm
iowdave
hi all an update on my problems i change the front precat and the main cat and the noise has all gone so must of been something to do with them thanks for all the replys and i hope this is useful to other members .. Thumbs Up
Post #63267 10th May 2011 7:31am
