Home > Maintenance & Mods (L322) > Rear Diff Upgrade.
Norm
Canada 2008 Range Rover HSE 4.4 V8 Alaska White
Rear Diff Upgrade.
Hi Guys,
I've done a quick search and can't find the info I need so I'd like to pick your brains.
I have a 2008 4.4lt. Jag engined HSE with normal open rear diff. Anybody know if it's possible to swap in an e-diff from a Supercharged? Are the ratios the same, I'm not bothered about the electrical side I can always run a couple of wires to a switch to manually operate it.
Thanks guys.
Post #583147 10th Feb 2021 6:07pm
mjdronfield
I’m sure this has been discussed/documented on here somewhere, so it is definitely possible.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #583156 10th Feb 2021 6:42pm
mjdronfield
https://www.fullfatrr.com/forum/topic42005...=rear+diff
https://www.fullfatrr.com/forum/topic39346...=rear+diff
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #583162 10th Feb 2021 6:59pm
Norm
Thank's for your replies guys, on reading the links I think it might be best if I stick with what I have and concentrate on doing other improvements for now. I might give it a try in a year or so after I've retired and the car isn't a must have daily driver.
Post #583422 12th Feb 2021 3:40pm
