![]() | Home > Maintenance & Mods (L405) > Getting a tow bar fitted to MY17 SV |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 ![]() ![]() ![]() |
The LR Accessory farmer's hitch towbar is about £1000 fitted by main dealer, quick and easy to fit/remove, higher nose weight than deployable, and no risk of the mechanism seizing. Depending on circumstances you might want to fit some kind of locking mechanism. Only Range Rovers since 1988 |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 786 ![]() ![]() ![]() |
I had a removable Westfila tow bar fitted on my drive by PF Jones for under £800.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 ![]() ![]() ![]() |
If your going to carry bikes predominantly? How will your bike rack fit to the tow bar? My deployable bar has a swan neck type of arrangement so may not suit your purpose? And again, if you need to bolt some type of attachment to the swan neck? Then it may not retract with that attachment in place? Not a problem for a few weeks holiday use but may become problematic long term! So a fixed OR removable type one might be better? |
I carry bikes with a Thule carrier on the Westfila removable tow bar with no problems or additions to the tow bar. MY23 D350 HSE
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Ditto - Thule carrier on the Westfalia detachable swan neck here and its great. We only fit it when needed and you are only talking a minute or so to fit it to the car - no big deal compared to lugging the bike carrier out the garage!
