![]() | Home > Maintenance & Mods (L322) > Oh Oh Fuel Burner question alert |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
At a guess you dont have park heating enabled in the ccf for the fbh to run without ignition on, as for charging your small battery just pick up a live from rear fuse board and run it through a voltage sensing relay to the battery then it will charge with engine running I would think is the easy way to do it. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
Can’t help with the FBH stuff, but if you pull the fuse for the clock at 12 and put it back in, the clock will go to 12.... so the time will be correct.
12ty Member Since: 22 Dec 2020 Location: East Northamptonshire Posts: 14 ![]() ![]() |
Hi mjdronfield, I am liking the idea of the fuse for the clock, simple and brilliant. |
Hi kds2 can I ask what is ccf? I have been searching google today for voltage sensing relays, who would of thought it. Loads of options, thanks. ![]() I have read about the park heating not always being enabled to run without the ignition on in other posts. Most of them seemed to be with vougue owners as they are talking about screens. Mine is a HSE and their is a control in the midi unit which allows you to set the heater and operate the heater from the clock at your own chosen time. Not sure if this still has to be activated within the ccf thing you mention on a HSE but if you read the page from Rave attached regarding the midi unit it does appear to control the unit as standard. Would be good to know if any HSE users have had the FBH working from this midi.
see section 9
CCF = car configuration file. Would have thought reading the rave pages that it still might be possible to have park heating enabled, I found the info for mine on the Gap Diagnostics web site printed it off and asked Old Forge Garage here in Lincoln to do it for me, I guess you could have a look on there to see if any thing about the HSE model park heating. |
Hi KDS2
Sorry could`nt tell you the true cost, because I had all the information printed out for him and had not done it before he wasnt sure if it was done right (it was just took couple of days for it to appear on screen) the price was reduced for a normal plug in cost (did slip something into the box of the charity they were supporting to make up for it) so at a guess whatever your local guy charges should just about cover it (it took less than half hour) as for main dealer doing it well into three figures know doubt ! |
https://www.fullfatrr.com/forum/topic45058.html?highlight=heat
