![]() | Home > Technical (L322) > 2012 L322 Blower Motor Replacement Question |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 ![]() ![]() ![]() |
I would have thought so yes but the fuse to the resistor is 40amp so quite will take quite a current. The wiring to that resistor is pretty chunky cable though
Goodluck247 Member Since: 08 Jan 2021 Location: London Posts: 30 ![]() ![]() ![]() |
I was reading your post the other day.. its very involved
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 903 ![]() ![]() ![]() |
The FSR is down on the offside of the central tunnel so it may not be too visible, even with the dash out.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
if its just the connector that you require there's one on eBay (its the same plug as BMW)
Cheers thanks |
It is the same part in the 2010 on cars too |
