Home > eBay & Bargain Spots > Anyone after new tyres? 255/55/20 Pirelli Zero All Season
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Thanks, Stan.
Will it fit in the spare wheel well with the lifting kit in place, do you know?
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #583389 12th Feb 2021 1:04pm
not sure but someone will tell hopefully...but you can leave the spare 'as is' and only do the road tyres. ... - .- -.
Post #583390 12th Feb 2021 1:06pm
RRDunc
I’d rather have 5 the same. There’s a 1 inch diameter difference without taking wear into account.
Post #583398 12th Feb 2021 1:48pm
Weegie
Dunc.
They will go in but it is a very tight fit. Some have shaved a bit off the spare wheel housing to ease it a little.
I had one in place and I took the RR jack (the wire contraption) out as I have a Sprinter jack. As I was taking it out it slipped and jammed behind the spare wheel. I had to get a mate to come over to lift it out as I have some problems which preclude lifting weights. Sad . That was with the lifting kit. John
GAP iiD BT
Post #583402 12th Feb 2021 2:02pm
RRDunc
Thanks, John.
Post #583429 12th Feb 2021 4:06pm
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Just got a set of these from Phil, fantastic new tyres at a fraction of the cost Thumbs Up Thumbs Up 2014 vogue se
Post #584801 22nd Feb 2021 10:24am
DrRob
I dont think 55 will fit with the spare wheel lifter in place. I recall a thread.
Will fit without lifter and a little air taken out.
I'm fitting 55 profile General Grabber AT3 as my next set and will have one as a spare Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #584817 22nd Feb 2021 12:48pm
chefkenmore
That’s correct, I put GG3s on last year , changing from 275/45/20 to 255/55/20 spare doesn’t fit!
So I kept one 275/45 as the spare!
Got the Pirelli’s as summer tyres Thumbs Up 2014 vogue se
Post #584823 22nd Feb 2021 1:46pm
RRDunc
@DrRob and ChefKenmore, thank you. I'll just have to keep an eye out for someone doing this with 255/50R20 tyres.
Post #584827 22nd Feb 2021 2:35pm
DrRob
55 will fit as I said above Thumbs Up
Remove tyre lifter
https://www.fullfatrr.com/forum/topic42529-30.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #584845 22nd Feb 2021 5:31pm
RRDunc
I've only just fitted the tyre lifter! At my age and with my arthritis (osteo and Rheumatoid) I've got sod-all chance of getting the spare out without it!
Post #584847 22nd Feb 2021 5:46pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Remove tyre lifter
just use one 255/55 as the spare, just to get you home, like others with space saver wheels max 50mph.
Post #584848 22nd Feb 2021 5:51pm
