Home > Technical (L322) > FBH Fuse Location 2009 Facelift TDV8
Sub5
United Kingdom 2009 Range Rover Vogue TDV8 Zambezi Silver
Hi all,
New to the forum and have owned my L322 since November. Love it to bits!
I've been searching everywhere to find the fuse location for the FBH on my facelift 3.6TDV8. This is to disconnect it from the battery and force a reset. I have been given lots of fuse numbers for the glovebox department e.g. 59 or 28 but they are blank... some suggest the engine bay but I can't find the fuses here and again I am not getting given a certain fuse number but lots of 'I think it is...' answers so don't want to pull the wrong one!
My remote for the FBH works fine and starts the blower but the heater is not kicking in so I want to try the reset before taking it to a specialist.
Thanks!
Sub5
Post #580402 19th Jan 2021 10:30am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Fuse 59 behind the glovebox. 2nd in from the right on the bottom row. Take out for 30 secs, put back in
Ask me how I know Rolling with laughter 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #580407 19th Jan 2021 11:04am
Sub5
Thanks Tugger, 59 is actually blank on mine although I put a spare fuse in here and it did nothing. I'm inclined to think it is in the engine bay but not sure which one Thud
Post #580413 19th Jan 2021 11:20am
Tugger
Very strange...should be 59. Dunno what's going on there - maybe a DIY retrofit? 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #580416 19th Jan 2021 11:24am
Sub5
It's definitely a factory option as it comes up on the cars spec when searching the VIN code. I think the issue is when the car was facelifted (as mine is) the fuse for the FBH moved to the engine bay.
Post #580417 19th Jan 2021 11:37am
Tugger
I guess you can get the same result by disconnecting the battery for 30 secs or so, that should do the trick.
Alternatively, it can be reset via diag tool such as Gap IID - if you dont have one, they are highly recommended round here. Expensive initially, but they pay for themselves very quickly and hold their value well on resale. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #580419 19th Jan 2021 11:40am
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Hi, I have a 2010 3.6 and the FBH fuse is in the boot, can’t remember which fuse it is but it should say on the panel when you remove the cover.
Post #580488 19th Jan 2021 5:47pm
Sub5
Thanks I'll have a look there. I have a feeling that is for the Webasto receiver but could be wrong!
Post #580502 19th Jan 2021 7:48pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I just unplugged the unit in the boot as it’s very accessible
Post #580506 19th Jan 2021 8:58pm
Sub5
I think unplugging this just terminates the receiver for the key fob and may lead to having to pair the fob again. I need to disconnect the actual FBH itself... No guarantee this will work of course!
Post #580508 19th Jan 2021 9:14pm
darrenm
plugging into to diagnostic would be Easier
Post #580510 19th Jan 2021 9:25pm
drakes
On the facelift models the fuse for the FBH is under the bonnet, can't remember which number but there is a picture guide thing on the lid. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #580547 20th Jan 2021 1:17pm
kooky_guy
It's E8, I believe. 2010 4.4 TDV8 Vogue SE
Post #580658 21st Jan 2021 3:37pm
