Home > Technical (L322) > Simple question. Tyre valve replacement |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 869 |
The TPMS valve stem is connected to the TPMS sensor inside the tyre. You can just replace the stem if your TPMS sensor is still working / has plenty of battery life left in it, although it may be prudent to change it whilst you have the tyre off, esp. if they’re of unknown age. Obviously need the correct sensors, readily available on eBay and generally come with the new stem anyway.
19th Jan 2021 8:12am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
I've never changed just the stem, so can't comment on that.
19th Jan 2021 10:54am |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Thanks All
19th Jan 2021 11:12am |
So, after having the valves changed I had "check all tyres" warning and have now driven nearly 20 miles.
20th Jan 2021 1:48pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Code it out with iid tool |
20th Jan 2021 2:02pm |
Ha, nice idea. That is not a solution for me. I like everything to work as it should, and if it doesn't work I will keep going until it is fixed.
20th Jan 2021 2:12pm |
You bought the wrong vehicle if you want everything to work as it should |
20th Jan 2021 2:13pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
do a battery reset, it 'might' reboot the relevant ecu's ..... ... - .- -.
20th Jan 2021 2:14pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3102 |
I noticed the other day that the TPMS has been switched off on the Supercharged RR that I bought recently and it's something I'd like to turn back on after having a blowout whilst towing in our 2012 which doesn't have TPMS.
20th Jan 2021 2:23pm |
Stan - sorry I should have mentioned that. I did that in the tyre place as well. +ve and -ve terminals touched together. |
20th Jan 2021 2:57pm |
Dinng maybe I am just better at fixing things, or paying people to fix things than you are. |
20th Jan 2021 2:58pm |
David it doesn't see the spare AFAIK I think there's a sensor in each arch that picks up the signal from the tpms transmitter |
20th Jan 2021 3:01pm |
Sausage man
20th Jan 2021 3:02pm |
£10 ?
20th Jan 2021 3:28pm |
