Home > Technical (L322) > Manually close sunroof '09 L322?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi everyone,
I have yet to open the sunroof on my '09 L322 Autobiography for fear that I won't be able to close it!
I looked through the owner's manual and the service manual but I can't find any mention of a method to manually close the sunroof in case the mechanism has some failure.
Does anyone know if there's a way to manually close the sunroof?
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #580162 17th Jan 2021 8:36pm
mark towill
Canada 2008 Range Rover HSE 4.4 V8 Stornoway Grey
I do not know if I can help but search Elliot the farmer with I believe a 2006 td6 l322 he found a crank to manually shut the roof in the back of his FFRR. He is in a wheelchair [ Elliot] I know my 2008 does not have such a crank but maybe an allen key would work. If you can find the access near the sunglass compartment between sun visors. Hope this helps
Post #580193 18th Jan 2021 1:50am
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
Re: Manually close sunroof '09 L322?
Larry
Never needed to do it on my L322 but have done it on my P38.
At the very worst you would need to remove the motor and turn the cog by hand/screwdriver but there is bound to be a slot in the motor mechanism to allow this to happen as there is on the P38. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #580231 18th Jan 2021 1:00pm
Simon_CSK
Just spent a little time looking at the motor and sunroof assembly on EBay.
The motor appears to have a cover on the cabin side which I would hope is removable and will allow the sunroof to be manually cloded. Current cars
Range Rover CSK
Discovery 3 HSE
Post #580233 18th Jan 2021 1:34pm
