Home > Technical (L322) > Brake light fuse
Bazzashadow
Brake light fuse
I have a l322 2012 vogue se
And one brake light is not working
I have found the fuse for the one that is working and it also does the active cruise control and it is ok
So my question is
Do these have two fuses
One for each side on the brake light
Thanks
Post #580046 16th Jan 2021 8:14pm
Goulime
France 2012 Range Rover Autobiography TDV8 Stornoway Grey
Hi Mate
Have you found the issue ? i've got same trouble on mine...
Thanks
Guillaume
Post #668782 10th Jul 2023 9:03am
Merchy
From the fuse lists I have seen, there is only one fuse, but check the manuals in the 'Wiki' section.
Post #668812 10th Jul 2023 1:58pm
Bazzashadow
It went to an electrical specialist and they said the bcm module had been spiked and then bypassed it
Not ideal but it works
Tow bar brake light doesn’t Evil or Very Mad
Post #668913 11th Jul 2023 6:13pm
