![]() | Home > Technical (L322) > Alternator or battery? |
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 ![]() ![]() ![]() |
Did you get to the bottom of this? |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Checked battery/charging today.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
The minimum with engine running is too low unless it was a glitch, you need to check that one again. Run the check after starting. BMW i3 Electric Car
Thank you, I’ll try it again. I think this reading was taken as I started the engine.... |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
As I recall, the voltage remains around 13.8V after startup for a few minutes and should them rise to over 14V, as the alternator starts to charge the battery, once all the electronics have settled down. Got - 2017 SDV8 Autobiography in Loire Blue
I’ve been monitoring the alternator and battery and while the alternator is charging at 14.7 - 14.9 the new battery never reaches above 12.3V. For example, on Sunday I checked the battery reading at 12.2V, I then drove for an hour and a half but when I rechecked the battery it read 12.3V.
Auto electrician has traced the battery drain to fuse 49. Specific component still to be identified (probably satnav unit). Replacement battery and alternator probably never required! |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Battery on L322s are always a pain. |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
New battery every year😲! Previous cars:
appj62
