Home > Maintenance & Mods (L322) > Secondary Battery for 2007/57 L322 Vogue SE TDV8 3.6
blackcat99
Hi all
I am considering (actually, going to be) fitting a secondary battery to my L322. I am getting the fitting kit from Luxury Landrover Upgrades (they supplied my replacement reversing camera) and according to the video it is a 5 minute job.
However, I am unsure about what is the most suitable battery to fit, given that it will go in the boot recess under the rear fuse panel.
Recommendations for the battery type (not make), amperage etc would be most appreciated.
Many thanks
Peter Peter J Davies
Post #578753 6th Jan 2021 9:04pm
this thread refers to the 2002 td6 but it should give you some ideas,
https://www.fullfatrr.com/forum/topic26065.html ... - .- -.
Post #578754 6th Jan 2021 9:12pm
Laurie915
Australia 2010 Range Rover Autobiography TDV8 Buckingham Blue
If you tow a caravan you might want to consider this kit !
http://www.traxide.com.au/diy-dual-battery...t90-c.html
Laurie
Post #578762 6th Jan 2021 10:33pm
