Home > Technical (L322) > Locked out with flat battery |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 283 |
Sorry, MY09 TDV6, should have said. |
12th Dec 2020 1:09pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
are you not able to use the key to unlock the door? 2012 Vogue 4.4 TDV8 - Current
12th Dec 2020 1:16pm |
Nope, nothing doing although on the bright side, after searching the forum I now know it’s something I need to fix. |
12th Dec 2020 1:24pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3772 |
Check underneath, you might just get to attach a jump lead to the starter motor cable.
12th Dec 2020 4:06pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
You should be able to use the key in the door lock to open it, the lock will be covered by a plastic cover piece which needs popping off. Iirc it’s on the passenger door. You should then be able to put the key in and turn it.
12th Dec 2020 4:16pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
As above you just need to put 12V on pin 9 and an earth on pin 13 of your towing socket. Bits of wire pushed into them and connected to a battery would allow you to open the doors. |
12th Dec 2020 4:54pm |
Thanks everyone.
12th Dec 2020 4:57pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
It’s an easy mistake to think that the plastic cover on the passenger door handle is the actual lock, as I found out .... 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
12th Dec 2020 4:58pm |
https://www.westerntowing.co.uk/caravan-12s-wiring-diagram/
12th Dec 2020 5:05pm |
Thanks Joe, had a look at a few 7 pin wiring diagrams but none make as much sense as this.
12th Dec 2020 5:10pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
Pm sent |
12th Dec 2020 5:39pm |
Right then, a plan of action for tomorrow
12th Dec 2020 6:22pm |
Tried that and it looked like it needed too much effort to get it off, which either means it not supposed to come off, or it’s another feature unique to some models and not others. I quit before I broke it. |
12th Dec 2020 6:25pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
12th Dec 2020 6:50pm |
