Home > Technical (L405) > Rear side light ns
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Rear side light ns
Dont you just love progress not sure I see more duff led lights than we ever had with filaments!
The odd thing is on door open the light works but regularly just does not want to work. Done a dry out in the oven but still no joy. Looks like its time to part with £100s Rolling Eyes
Anyone any suggestions the unit looks non serviceable to me. Help got CAR OWNER VIRUS!
Post #577008 22nd Dec 2020 6:48pm
is this as per your car profile or a L405?? ... - .- -.
Post #577051 23rd Dec 2020 9:43am
bleeperman
L405sdv8 Stan, but still have l322 td6. Help got CAR OWNER VIRUS!
Post #577056 23rd Dec 2020 10:32am
ah ok, so which light are we talking about.. ... - .- -.
Post #577059 23rd Dec 2020 10:58am
bleeperman
Side light and brake light but as you unlock lights up and goes out left side!
When you turn on auto or manual mostly does not work. Side bit is ok. Help got CAR OWNER VIRUS!
Post #577060 23rd Dec 2020 11:40am
sorry chap i cant get my head round your description of your problem....i had a bad night so its probably me..
hopefully someone will be along soon and answer your query.. ... - .- -.
Post #577064 23rd Dec 2020 12:17pm
bleeperman
Rear side lights intermittent
New unit cured the fault, guess unlock is a momentary flash that doesn't trigger the solid state fuses. When on for a longer period they must give up and open cct. So the only preventative maintenance I would suggest the condensation is the culprit. Help got CAR OWNER VIRUS!
Post #578417 4th Jan 2021 5:01pm
supershuttle
The condensation thing is interesting. I had a bit in mine (lights all worked though) drilling a few extra drain holes did not work.
So I just injected a bit of soapy water, got to work with the compressor and lo and behold bubbles appeared on the backplate (round a screw or a moulding IIRC) a bit of black sealant and Roberts your Mothers brother - no trouble since. Might save someone a few quid, although I'm sure I will fork out for the newer lights in the future. Very Happy Geoff
Post #578473 4th Jan 2021 11:26pm
