Home > General > Connecting iPod to range
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
This is a cheap way of boosting the volume from the aux port, I had one in my 08 and it worked perfectly, it also allows you to keep the main volume at a normal level so the navigation isn't too loud.
http://www.amazon.co.uk/Boostaroo-Audio-Am...B0000DBHFS
I rerouted my rear aux up to the top portion of the arm rest and left my ipod in there. 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #62421 2nd May 2011 8:23pm
iancollins
England 2016 Range Rover Vogue SDV6 Causeway Grey
use the proper LR ipod kit..
it works perfectly and you can change tracks and volume thru steering wheel buttons
also sound is perfect Thumbs Up
Post #62475 3rd May 2011 9:33am
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
Yeah but how much will that cost? I prefer a cable or connecter solution. That way i can use the ipod in other cars.
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #62480 3rd May 2011 11:13am
Austin
England 2004 Range Rover Vogue Td6 Java Black
can you connect your ipod to a 2004 FFRR? or does it mean you loose the cd changer?
Post #62536 3rd May 2011 7:23pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
hi all, as a new boy i am full of questions!!
one of the first things i want to do is see if it is possible to use my ipod in my 2005 FFRR?
if so what is the best kit to buy?
thanks in advance for any help.
Post #62659 4th May 2011 8:05pm
