Home > Maintenance & Mods (L322) > Brake pad warning
Captain Slog
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Brake pad warning
Just got the 'Check brake pads' warning appear. I does not state front or rear I'll have to check. Anything I need to be aware of if I do the Job myself? and are after market pads OK? there seem to be lots on fleabay, what do folk recommend?
Martyn
_________________
Currrent: 2005 FF Range Rover L322 Vogue TD6
Gone: 1999 Range Rover P38 HSE TD6
Gone: 1985 Land Rover 90 SWB diesel
Post #62280 1st May 2011 12:04pm
dan_uk_1984
I never had any problems with Mintex or such.
The only problem is now you've triggered the sensor you'll have to replace it. More than likely with the front/rear bias it's your fronts that are worn but you should check all, as there is no point ignoring the rear if they are going to go through a £10 sensor for the sake of £15 worth of pads.
Buy some brake cleaner from halfrauds and a small wire brush as they tend to collect a lot of dirt that then bakes on.
Whilst you've got the wheels off and the EAS in high you might want to give your air springs a liberal coating of silicone spray to prevent perishing.
Post #62281 1st May 2011 12:17pm
Captain Slog
Hi Dan
Thanks for the advice.
Why does the sensor have to be replaced?
_________________
Post #62282 1st May 2011 12:28pm
dan_uk_1984
Hi Dan
The sensor activates by wearing through a wire as it comes into contact with the disc - there is usually about 3mm left on the pad at this point.
There are only two sensors on the car, one front and one rear which means if you have a binding calliper you can chew through one set of pads and get no warning. So when taking the pads out, check for even wear.
Dan
Post #62283 1st May 2011 12:38pm
Captain Slog
dan_uk_1984 wrote:
Hi Dan
Dan
Thanks for the support Dan.
_________________
Post #62287 1st May 2011 12:50pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
if you know your pads and discs are ok, then it could be that the wheel has worn through the wire and caused a short circuit, this is what happen on my front sensor (which is on the passenger side front wheel, rear sensor is on drivers side rear wheel) if you find that the wheel has worn through the wire make sure to check the brake pipes as it is a common problem for the wheel to rub through the rubber brake pipes when the wheels are turned to full lock.
Matt
Post #62319 1st May 2011 5:05pm
