Home > In Car Electronics (L322) > Anyone upgraded their hk speakers to these?
Danwilderspin
https://www.ebay.co.uk/itm/331811967086
Thanks Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #577652 29th Dec 2020 12:40pm
mjdronfield
These look very similar...
https://www.fullfatrr.com/forum/topic57819.html?highlight=focal
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #577659 29th Dec 2020 1:27pm
Danwilderspin
They look like 2piece components of the same thing cheers Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #577695 29th Dec 2020 6:19pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Not quite, no...
The 3 way kit you linked is a 4-Ohm set of speakers, whereas the ones I installed in that thread are a 2-Ohm kit.
The difference is that 4 Ohm speakers need twice as much current to achieve the same volume. So (as far as I understand), you're going to need to tweak the balance of the speakers to have them all sound as equally loud.
The amp will need to drive more power to those 4 Ohm speakers to achieve an equal sound.
In theory, you can just knock the front/rear fader forward to do this, but I figured I'd rather stick to the original spec's and used the 2 Ohm speakers instead.
I also ignored the crossovers provided and retained the original wiring to make use of the original DSP and it's setup - my understanding is that using the passive crossovers may have affected the timing of the Logic7, causing a degradation in the overall sound quality when using Logic7, but also possibly in the timing of the 14 speakers.
I'm not an expert on this, was just what I read around when researching, so very happy to be corrected by someone who knows more definitively Smile
Post #578144 2nd Jan 2021 4:48pm
