Home > Technical (L322) > L322 2004mod 3.0TD6 Sport mode, won’t start
Svennis
Norway 2004 Range Rover Vogue Td6 Barolo Black
Hi All.
Hope you do fine:-)
I’ve got a strange problem with my L322 2004 mod 3.0TD6.
The Car was fault free when I parked it yesterday, when I should start it today, it showes sport mode In the display even though the gearshifter is In P, and when I turn the key for start, Nothing happens...
I’ve got a hawkeye diagnostictool, and this doesn’t show any faultcodes that gives any good indication for the fault.
Do you have any idea what this can be? And where I should start problem searching?
Best regards
Svennis
From Norway
Post #577473 28th Dec 2020 11:29am
Check your gear selector rod hasn't seized up .
Post #577476 28th Dec 2020 12:01pm
As above.
It’s not registering it’s in P, which is why it won’t start.
It will either be that the selector lever on the gearbox is stuck or the linkage cable is frozen.
Possibly the position sensor/inhibitor switch on the right side of the gearbox. There is nothing that can't be fixed with a hammer😜😜
Post #577480 28th Dec 2020 12:24pm
Svennis
Hi all.
Just wanted to give an update regarding my problem.
When I checked my fuses, fuse nr 5 was broken.
GOT some tips from a mechanic to check the alternator, wich where my problem.
It was a bad contact on the alternator, used some WD40 to clean it, changed the fuse, and now the Car is all well:-)
Best regards
Svennis
Post #577778 30th Dec 2020 2:06pm
