Home > My Range Rover > New owner L322
Blitzsah
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
New owner L322
Hi all,
Thought I should introduce myself here after last week collecting my 2011 4.4 TDV8 L322.
I decided to take the plunge after previously owning a 2016 Golf R which really was an impressive car. A lot of my friends must be thinking I am bonkers switching from that to the FFRR but there is something about these cars that I have always loved. I used to work for some years in the Solihull factory where the L405 is made, L322 had just been deprecated when I started there. I think this may have something to do with my interest in the brand!
The car has done 86k miles with a full service history (mostly). She is booked in for a full service at my local specialist next week. I have already found a few issues (it wouldn’t be a Land Rover without some kind of issue would it?), such as oil leak from rear of engine and some belt noise when cold.
I must say this forum is a real encyclopaedia, I’ve spent ages just reading through numerous threads about common issues. Will definitely be tackling the oil cooler replacement by myself thanks to this forum I think!
Anyway here is the one photo I have of the car before I picked her up. Colour is Orkney Grey. Will try and get some more pics in the daylight over the Christmas break!
Cheers,
Steve
Post #577021 22nd Dec 2020 7:44pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Looks nice & welcome to the Forum.
As you have already mentioned, the Forum is full of information & excellent members. If something needs to be done, you'll more than likely find out how to do it on here .
Enjoy Very Happy
Post #577025 22nd Dec 2020 8:14pm
Blitzsah
It's had a full service over christmas and the garage noted the following issues:
Both rear shock absorbers leaking slightly
Rear brake pipes corroded
Rear prop shaft centre bearing is cracked
Rear exhaust heat shield broken
Rear brake pipes are corroded
Oil leak from oil cooler
Not a great start to ownership but I was expecting some issues and it could be worse.
Getting fixed this week:
New rear prop shaft installed with bearing, new heatshield and new oil cooler assembly install.
I will have to tackle the other issues at a later date!
Post #578677 6th Jan 2021 4:42pm
mjdronfield
It’s quite normal for the adaptive dampers on the rear to leak or mist slightly. So it’s to be expected if it’s only a misting.
Mine is currently in the garage for rear brake pipes to be replaced... hopefully get it back tomorrow.
Yours might be the first one I’ve noticed with a silver grille, but black horizontal bar and fog light surrounds. Or I’ve not been observant enough 🤣.
Normally it seems to be all 3 silver or all 3 dark......
Looks cracking mate.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #578692 6th Jan 2021 5:12pm
Highroller
These are all know L322 issues. Would you not contribute towards the brake pipes, this could save you a lot of money at a later date.
Post #578693 6th Jan 2021 5:12pm
GGDR
most people leave the rear shocks until they proper leak
it's a bit of a "they all do that sir" situation
. Cheers, Greg
Post #578694 6th Jan 2021 5:13pm
GGDR
bit of a combo of black in-fills for the 2012 update (vs grey)
and the black splitter bar / fog surrounds being a Vogue and not SE or AB
There were not as many Vogues in 2012 which is probably why you haven't seen too many with this 'face'
Mostly 2012 was Westminsters and AB's as the run out kicked in
. Cheers, Greg
Post #578697 6th Jan 2021 5:19pm
Blitzsah
Thanks for your comments guys.
Interesting info about colour combinations on the front end. I like it anyway!
Glad to hear these are all known L322 issues, yes I will be getting the brake pipes done ASAP but simply not enough time this week. I wanted to do the oil cooler myself but in the end I gave in as it was already in the garage for the rear prop shaft replacement!
Post #578701 6th Jan 2021 5:27pm
mjdronfield
I see. Mine is a 2011 Vogue SE and all dark....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #578703 6th Jan 2021 5:32pm
mjdronfield
As oppose to all 3 silver like Haylands’s
Though I dare say there are loads like yours and I’ve not noticed.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #578705 6th Jan 2021 5:40pm
Blitzsah
Great pics I see exactly what you mean now. All the combos look good! Yours is nice with the dark grille especially with the darker paint, tidy. Very Happy
Post #578708 6th Jan 2021 5:50pm
GGDR
ok interesting! Thumbs Up maybe a delete option? Cheers, Greg
Post #578710 6th Jan 2021 5:54pm
mjdronfield
I think in 2011 it might have been just the AB with the silver grille etc.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #578713 6th Jan 2021 6:11pm
GGDR
Nah mine's SE with the silver. 2011
 Cheers, Greg
Post #578729 6th Jan 2021 6:45pm
mjdronfield
No idea then 🤣 I see mine has Jupiter finish....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #578734 6th Jan 2021 6:55pm
