Home > Technical (L405) > Clicking noise from rear.
Edgey808
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Hi All,
Last couple of weeks, I’ve noticed a clicking from the rear when coming to a stop and then turning left or right, it’s sounded like a brake pad was jumping somehow, looked at rear brake disc, all looks ok nothing looks loose.
Do you think this could be a rear diff issue?
Car is on 74k miles, and I dont see any oil changes of the diffs yet?
Thinking of attaching the go pro underneath somehow to record the noise? 🤔
Any advice appreciated
Thanks
Stephen
Post #576426 17th Dec 2020 10:20am
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
That sounds like the problem I am having. It’s booked in under warranty to have the transfer box reconditioned. Apparently you can change the oil but that is only a temporary fix. Mine is a 16 plate with 65k on the clock.
Post #576853 21st Dec 2020 4:01pm
