Home > Technical (L322) > Reduced Engine Performance...AGAIN!!! |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 240 |
**UPDATE UPDATE**
26th Jan 2021 8:15pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3074 |
The rocker cover is the valve cover on the top of that cylinder head. Removing it will allow them access to the timing gears for that cylinder head.
26th Jan 2021 8:19pm |
Actually just re-read it. So yellow and green spikes should overlap and trigger at same time but they are out of sync do would need realignment?? Current Cars
26th Jan 2021 8:20pm |
Ok makes sense. Is that a big job to remove the rocker cover. Will this need new gasgets etc? Current Cars
26th Jan 2021 8:21pm |
**Another update**
26th Jan 2021 8:27pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Least you've managed too get an answer on it mate unlike the others.
26th Jan 2021 8:57pm |
Yes totally get it. How would it go out of line? Age/time or someone sickikg about with it like the previous owner?
26th Jan 2021 8:59pm |
Could be if someone done the chain and didn't time it properly. Could have happened if the chain was worn out and jumped a tooth. Always a thousand reasons why it could have happened I guess. Its upto you mate what you do going forward. Only thing I would say tho is just stick with the one garage for stuff you cant do yourself. Martin might not be the cheapest but you pay for more with martin then a plug and go jobbie with most garages. You'll love it tho when you get the car back and you can hear the charger scream with power |
26th Jan 2021 9:11pm |
I have given martin the go ahead. It is probably more than I wanted to pay but you are right. I took it to a garage whenI first bought it and paid ยฃ1050 and think now I probably overpaid anddidnt need an item or 3.
26th Jan 2021 9:20pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
I knew Martin would come up trumps Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
26th Jan 2021 9:23pm |
Might explain the rattles of nder the bonnet too just hope that is it and nothing else is unearthed upon taking the rocker cover off Current Cars
26th Jan 2021 9:26pm |
At least youโre heading in the right direction.
26th Jan 2021 10:11pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
If its jumped a tooth the likelihood is that the timing chains, are stretched and need replacing, hopefully someone has already done them and made an arse of it.... |
26th Jan 2021 10:14pm |
Two arses here.....one who sold it and one who bought it!!!
27th Jan 2021 9:05am |
