Home > For Sale & Wanted > [SOLD] 2007MY Supercharged
Classic888
After five and a half years of ownership I have decided that I now longer need the two Land Rover vehicles I currently own
So up for sale is my 2007MY Range Rover 4.2 Supercharged
First registered November 2006 (56)
Java Black with Ivory Interior
Standard specification for the Year with the exception of Privacy Film to the rear
Current mileage is just under 165,000 miles, but will increase slightly
MOT due 23rd December 2021. Passed on the 10th of December, with no advisories
Apart from the CD Player which gave up recently, everything works as it should to the best of my knowledge
The vehicle is best described as having done its mileage and is far from perfect, the paintwork has light scratches on most panels, the bonnet and front bumper have stone chips. The rear bumper was repainted and lacquered during the summer but has not been polished to get the correct finish. The paintwork certainly would benefit from some loving care. A few rust areas are showing in the usual places.
The four 20" road wheels were professionally completely refurbished about two years ago and have no kerbing marks, just a few minor surface scratches. Tires are the correct 255/50R20 Pirelli Scorpion and are all about 4mm across the tread.
The interior is in good condition but again is not perfect, signs of wear on the drivers seat and drivers door pull handle. there are a number of light scratches on the rear seat but no tears. Carpet and rubber mats fitted.
The spare wheel well is dry, the sunroof drain channels were also check a few months ago.
I purchased the RR at around 107,000 miles, the service book was not present, but was promised and yes never actually arrived! Details of services were provided and the name of the LR dealers that had carried out the services. So they were contacted but as both had changed ownership they said full details were unavailable.
December 2010 43471 miles Droitwich LR
November 2011 58367 miles Droitwich LR
November 2012 72183 miles Droitwich LR
December 2013 84796 miles Droitwich LR
After this Hadley Green London - no records kept
I had a former Land Rover technician carry out a 105k service at 107,825 miles during July 2015, he also completed in August 2016 a service at 118546 miles when the auto gearbox fluid, filter pan and sleeve were renewed plus both diff oils and the transfer box oil were changed.
Since then the following services/work has been carried out by myself and/or my brother in law, who has his own workshop business and specialises in LR and 4x4s. Two exceptions to this are noted below.
August 2017 129993 miles Service plus rear discs and pads
July 2018 141789 miles Service
July 2019 154216 miles Service plus both metal front to rear brake pipes and rear flexi pipes (genuine LR)
September 2020 162039 miles Service plus both front strut/air bags, all front suspension arms/ball joints, O/S/F
driveshaft, carrier bearing and seal. Four Wheel Alignment also completed
October 2019 Front Diff and N/S/F driveshaft*
November 2018 New Rear wiper motor and GPS roof Aerial
April 2020 Supercharger snout coupler replaced with solid type
April 2020 Primary and auxiliary belts (genuine) tensioners also replaced
April 2020 New Yuasa Battery
June 2020 System software Update*
*Independent Specialist
I have no doubt forgotten a few things but please contact me should you wish to know anything I have not listed.
Looking for around £4500
Pictures will follow when it stops raining and I can clean the vehicle
Post #575977 13th Dec 2020 3:13pm
Hermes
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Not sure if this is definitive, but I’ve used it with some positive results:
Land Rover Service Records
https://osh.landrover.com/
Post #576017 13th Dec 2020 7:35pm
Classic888
Hermes. Thanks for your reply. This service is for cars first registered much later than mine, but I did check just in case. Nothing unfortunately.
Sad
Post #576028 13th Dec 2020 8:20pm
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I would be interested to see some pictures, how bad is the rust?
Where is the car located? 2005 E60 M5
2006 L322 4.2 SC
2020 Tesla Model S Long Range
2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe
Post #576104 14th Dec 2020 11:36am
Classic888
Quavey. I hope to upload pictures tomorrow. Vehicle is currently in East Yorkshire, 12 miles north of Hull. Both rear wheel arches have paint bubble in the usual places. The top tailgate on the lower lip also. Early September when the service ect. was carried out a small hole the size of a ping pong ball was cleaned up and welded on the rear near side of the sill.
Post #576110 14th Dec 2020 12:09pm
SDB
Hi. Could you PM me more pics pls
Post #577712 29th Dec 2020 9:05pm
SDB
Do you have any pictures of the rust spots?
Post #577763 30th Dec 2020 12:02pm
Classic888
I will take some in the next few days if it warms up and I can clean the car.
Post #577772 30th Dec 2020 1:10pm
Classic888
Back up FOR SALE
Currently 171,000 miles with MOT until December 2022, last MOT 1 advisory NSF brake pipe, not done but I have the pipe. Supercharger had a full professional Rebuild in April 2021 (165724 miles) at a cost of £800+. The price reflects the need for TLC on the paintwork and the bodywork around the three usual areas; I have done temporary rectification to the two wheel arches. They were not that bad I thought it best to do something to slow down the deterioration. CD still does not work and a possible wheel bearing sound is obvious. Private Plate will be removed before sale. £4000 but open to Sensible offers.
Post #629351 22nd Apr 2022 6:38am
Classic888
Bump. Priced reduced to £3750.
Post #632929 26th May 2022 7:23am
Johnte
PM’d Thumbs Up
Post #633101 27th May 2022 10:48pm
