![]() | Home > Technical (L322) > L322 air suspension (not the usual Air susp fail) |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 ![]() ![]() ![]() |
Quick update, front appears to be down while the back is up and on start up I have self leveling suspension fault do not exceed 35mph |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 225 ![]() ![]() ![]() |
Could be one of front height sensors gone whatsit or even the link arm broken, you could try disconnecting link arm from suspension and moving sensor up and down a bit to clear the track, what code reader have you got. |
It looks like bad news on hoping that it was just a sensor. After looking at the data streams the voltage to 3 of the wheels was 2v or 3v and then the front left is pulling in a staggering 50v!
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 515 ![]() ![]() |
Has the garage who changed the arm either:
Yep arm was changed. It would be great if that was the issue. Although i think looking at the power going to each bag, that it is unlikely |
I would think the voltages you are reading are the output from the height sensors? The only other value would be the supply vopltage to the height sensors. The ones that matter in this case would be the sensor output which varies with height adjustment.
Turns out the bag had gone |
