Home > Technical (L405) > SDV8 2016 Auxiliary Heatee
cupples8267
Scotland 2016 Range Rover Vogue SE SDV8 Santorini Black
My RR SDV8 Vogue SE seems to have an auxiliary heater under the bonnet. I purchased the car second hand (Approved Used). How do I use the Aux heater? I was not supplied with a remote control- should I have been? Thank you all in advance.
Post #575237 6th Dec 2020 11:18am
It will Not necessarily have come with the remote. Check in the menus if you have timed climate, remote lark heat was an option, but iirc they come with the heater to help with warm up as standard, the ability to control it separately is the option. There is nothing that can't be fixed with a hammer😜😜
Post #575243 6th Dec 2020 12:29pm
cupples8267
Thank you very much. That makes sense
Post #575244 6th Dec 2020 12:33pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
I would expect a Vogue SE to have timed climate but remote park heat is the ultimate.
Post #575245 6th Dec 2020 12:36pm
Andy B
My previous SDV8 Vogue SE 4.4 (2015MY) had timed climate, but it did not show on the control screen and had to be turned on using the IID tool. So worth a check to see if you have a menu option for timed climate. SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #575260 6th Dec 2020 3:50pm
bear100
My autobiography came with this remote to activate the park heater
Also if you have the incontrol app there’s an option to turn it on from there too, the remote has a range of 50m but the incontrol works anywhere.
The heater will also kick in to help warm the engine from 5c and below
 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #575268 6th Dec 2020 5:24pm
knwatkins
I order to make more use of the FBH, you may want to check out my guide on how to retrofit remote park heat and activate timed climate...
https://www.fullfatrr.com/forum/topic57037-15.html Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #575291 6th Dec 2020 8:19pm
