Home > Technical (L405) > Rear door not opening
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Just wondering if anyone has experienced this and resolved it before i start pulling the door apart.
The drivers side rear door will intermittently not unlock and open.
I can hear the central locking motor “clicking” but when you pull the external handle the door won’t open as it is still locked.
The central locking button inside the door lights as locked and pressing it does not unlock the door.
All the other central locking buttons inside the car work normally and anytime you lock or unlock the car you can hear the solenoid on that door operate the same as the other doors.
If I pull the interior handle the door opens, the indicator light on the button extinguishes to indicate it is unlocked and i can open and close the door normally but as soon as you lock the car again that door locks and often stays locked unless you pull the interior handle or press unlock on the fob more than once.
It is intermittent as sometimes it unlocks normally.
Any ideas or experience of this appreciated.
Post #574014 25th Nov 2020 7:58am
mjdronfield
I replaced both rear Door locks on my TD6 due to this. Not at the same time, they both failed within a few months of each other.
I think there is a way to get the rear door open from the side of the latch, ie with the front door open, but that’s just from memory.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #574040 25th Nov 2020 11:59am
mjdronfield
Ah, ok, L405.... need to read more before I reply Rolling with laughter
I imagine the setup is similar though.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #574042 25th Nov 2020 12:01pm
Gibby
2013 Range Rover SE 4.4 V8 Causeway Grey
Check the battery.
Mine started doing this as well as throwing up other faults now and then. Battery was getting to the end of its life.
Gibby
Post #574247 26th Nov 2020 10:52pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
I had a similar issue with the front passenger door - same symptoms as you have except mine wouldn't open from the inside or outside. Did a lot of searching and eventually found some Land rover site in the US that suggested this is a problem with the soft close doors and can be fixed with ECU update. I checked and although my car didn't have any ECU faults the GAP tool did indicate that an update was available for the passenger front door module. I contacted Patrick at GAP and he sent me an ECU flash for the door module which I applied. Initially that didn't work but I then did the ECU reset (battery terminals) and that cleared the fault. I'm not sure if an ECU reset would have cleared the fault (might be worth trying that first) without the ECU flash but the combination seems to have worked.
cheers 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #574470 28th Nov 2020 9:51pm
