Home > General > No miles left....how far to go....... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7961 |
I managed about 30 miles on zero in my L322 one time
19th Nov 2020 7:57pm |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 257 |
Once got 45 miles out of a D3 that indicated zero range
19th Nov 2020 8:19pm |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 462 |
In my petrol L322 4.4 V8 (same as yours) I once tested this, as it's also fitted with LPG.
19th Nov 2020 8:45pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
I get twitchy when the light comes on and don't push it further than that... |
19th Nov 2020 9:15pm |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
After a couple of restarts with the fuel light on my 4.4 tdv8, it throws a panic and displays restricted performance. |
19th Nov 2020 9:29pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
When I had my old TD6 Rangie, I would be doing 600 miles travelling per week, at 60 miles each way commute. I always ran 'tank to tank', filling up every Friday afternoon after getting home, so I would sometimes end up with the fuel light coming on with 60 miles to do to get to the petrol station (okay it's a diesel, but we call them petrol stations!). I would reset the trip counter as soon as the light came on, supposed to come on with 60 miles range left, and then see which was more accurate the mileometer or the range countdown. Never managed to get to zero miles on the range counter, even after doing 75 miles due to a detour one time. Was a bit nervy though as when I refilled that day I put 99.6 litres of diesel in the tank! |
19th Nov 2020 9:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Nice pixels for an '03
19th Nov 2020 10:37pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 |
Sod the zero miles, look at the price of the fuel. You lucky so and so visiting from www.rrsport.co.uk |
20th Nov 2020 8:40am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Not a good idea with injection systems to run them out of fuel, all sorts of damage can be done. On LPG systems the fuel pump is often left running to stop the petrol under the bonnet boiling (or it was on my LPG Rangie). BMW i3 Electric Car
20th Nov 2020 8:49am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
You never go passed a petrol station when on empty, ever, I was wondering how many litres where going to be left as a reserve, could of got home again if I didnt fill up. Thanks Tim, the pixles where repaired 7 years ago when I got the RR and I must say the chap who did it has done a good job, well worth the money spent. If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
20th Nov 2020 9:47am |
And thats expensive here in Mid wales! If it dont work.......burn it! If the IId tool cant fix it.......burn the FF. If the FF cant be fixed......buy a Land Cruiser! If the LC cant be fixed..............................................BUY a horse !! |
20th Nov 2020 9:49am |
Never knew that, thanks It was on the first engine 'hiccup' that I immediately switched over to LPG and then filled up within a mile. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
20th Nov 2020 2:37pm |
