Home > Maintenance & Mods (L405) > Rear light casing and MOT
Gibby
2013 Range Rover SE 4.4 V8 Causeway Grey
Evening all,
MOT coming up next month and want to know if I need to cough up now or if I can wait for the right price for the rear lights.
Offside rear light housing is broken, not just a crack, but open to the elements. Lights all work fine.
Will it fail on this?
Gibby
Post #573103 17th Nov 2020 1:24am
pretty sure it would fail Gibby.... ... - .- -.
Post #573119 17th Nov 2020 7:51am
Mr Tee
I think it depends on if white light shines through, certainly used to be the case. Other mor learned folk will be here shortly....
Post #573124 17th Nov 2020 8:24am
Brian Considine
Re: Rear light casing and MOT
Yes - cracks etc used to be OK provided the beam pattern/light colour was not effected but now the housing itself has to be sound. 2003 Range Rover Vogue TD6
Post #573177 17th Nov 2020 11:08am
If you have the bits some Mitre fix might stick it all back together as a temporary fix There is nothing that can't be fixed with a hammer😜😜
Post #573199 17th Nov 2020 1:36pm
