Home > In Car Electronics (L322) > Shark Fin Antenna pod, which antennas does it contain?
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
I've trawled back through old posts and as best as I can determine, there's GPS and DAB antennas in the roof pod, however, I have both GPS and DAB working but there's a "spare" cable coming from (I think) the roof pod that I can't identify.
It's routed down into the right hand side fuse box. Can anyone identify it? What's it for?
I'd quite like to make use of this antenna, especially if it's a GSM / 900mhz antenna as its exactly what I need for a LoraWAN TTN Mapper device (very geeky, don't ask). Smile
Post #572822 14th Nov 2020 7:29pm
Siftah
Turns out the colour coding on the FAKRA connectors tells you what they are, so this one being leaf green means it's a "TV1".
Presumably it's not connected because my car has the hybrid digital TV module and just uses a single "digital tv" antenna.
Post #573953 24th Nov 2020 6:51pm
