![]() | Home > In Car Electronics (L322) > DVD playback issue? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
i gather you have rse?
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Hi Stan, thanks for reply, yes, it has rse and the dvd plays fine on a Sony DVD player at home...,, |
just a guess but take all the other dvd's out of the changer and just try this one single dvd.. ... - .- -.
Thank you, I’ll try this later.... |
Just tried but no joy, still the same blue screen with same message..... |
the only thing i can think of is to investigate the denso info in the wiki and see if the old tech in the FF is capable of decoding your newer disc.. ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7882 ![]() ![]() ![]() |
Does the car still play other DVDs correctly?
STAN: thank you |
So it’s a DVD with music videos on it? Not just music, so it has a normal DVD menu and chapter selection when you play it in the house, just like a film? 2011 Range Rover Vogue SE 4.4 TDV8
Hi, yes, a dvd film of a band in concert. It had PLAY, SONG SELECTION and SETTINGS in the Menu.....just a standard dvd. Not a copy! Dvd was released this year. |
That’s a strange one then. No idea.... 2011 Range Rover Vogue SE 4.4 TDV8
Thanks anyway |
been talking to my son re this and he reckons it could be a 'region code' problem....the UK is region 2 and its possible your disc might not be..
I wondered that, but then the players in his house would have to be region free. Not sure the error message would match. But then I’m speculating. 2011 Range Rover Vogue SE 4.4 TDV8
