Home > Duckworth Parts > 2011 rotary gear selector
tractorfactor
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Hi, the rotary gear selector in my 2011 tdv8 decided to stay in reverse this weekend. I believe these can be problematic on the later models like the l405. As they only fitted the rotary to the late l322 I cant find a lot of other members issues. Can you supply a new unit and does it have to be programmed? Obviously I cant move the car. Many thanks, Al
Post #571547 2nd Nov 2020 8:29am
Baltic Blue
I have had a similar problem with my 2011 tdV8.
Mine was stuck in P after being parked up for a few weeks.
I cleared it by cycling between high and low ratios and eventually it allowed me to move out of P and hence start the car and drive it in all gears.
The problem has never re-appeared to date after a couple of years.
I put a post on here describing the problem at the time, but sorry, I can’t find it.
Post #571555 2nd Nov 2020 9:50am
tractorfactor
Hi BB,
Thanks for the reply.
I was actually in low box reversing my trailer when it happened.
Went to put it into drive and nothing, locked in reverse.
IID indicated a gear selector solenoid lock failure.
Eventually I had to switch the car off.
Then I couldn't start it because it was in gear Crying or Very sad Had to leave the car stuck overnight.
I got the module out and stripped it down.
Solenoid works fine powered off a 9v supply so must be on the board.
Rebuilt unit back into park, and managed to start the car but no gear selection.
At least I got the car home via a tow and the transmission release lever.
Every day is a school day owning a RR!
I see a number of evoke and velar owners have had the same issue.
Cheers, TF
Post #571561 2nd Nov 2020 10:39am
