Home > Technical (L322) > Suspension fault - 30 MPH max. |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Dogey sensor |
24th Apr 2011 4:48pm |
xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274 |
I had this on mine & it was the cork filter on the suspension compressor in the spare wheel well. It was fixed by Land Rover Assistance in about 10 minutes with a replacement filter, which has been modified by Land Rover with a hole in it to stop it happening again as it is a common fault.
24th Apr 2011 5:27pm |
PJS Member Since: 06 Jul 2010 Location: Yorkshire Posts: 506 |
Thanks for that. I'll check it out with the dealer see what they think. |
24th Apr 2011 6:01pm |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Just had "Suspension Fault" come up on my screen - no mention of speed?
24th Apr 2011 6:51pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35284 |
brieff faults that come up could be loose connections on the various ecu's and sensors on the range or at worse it could be a failing item. ... - .- -.
24th Apr 2011 7:03pm |
jbarton Member Since: 20 Feb 2012 Location: Lexington KY Posts: 1 |
@xjsracer44- Is there another name for the "cork filter" you refered too? I am having the same issue with my suspension. I have called the dealership and they have never heard of a "cork filter". Any additional information would be apreciated. |
20th Feb 2012 5:41pm |
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 |
If you go into then boot in the spare wheel area, in the middle is a metal box containing the compressor, take the top off and at the back is the silencer, it's tapered and made of loads of little brass balls all stuck together. It's this that gets blocked and the compressor can't release air so can't adjust as it should |
20th Feb 2012 10:27pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
From your description, the correct term would be "sintered brass filter", they are commonly used to filter dust and dirt particles out of air. No longer FF owner but still interested. Present car Jaguar XE
20th Feb 2012 11:58pm |
blench99 Member Since: 18 Nov 2011 Location: northumberland Posts: 24 |
I had similar problems with my 06 vogue, i drilled a small hole in the filter but problem kept coming up on dash even when codes had been cleared. In the end my local independant dealer found it was a n/s/f levelling valve which i changed, reset codes and has been ok since. |
21st Feb 2012 11:29am |
