Home > Technical (L405) > Cruise Control Error
goodeone
United Kingdom 2013 Range Rover Autobiography SDV8 Loire Blue
Hi I’ve noticed my Cruise Control always allows the car to travel 1 mph faster than what I have set (set at 70mph car will sit at 71mph) anyone else notice this? This is my first Range Rover but every other car I’ve ever owned will sit at the exact speed set.
Post #571138 28th Oct 2020 2:13pm
mjdronfield
You prob need to set it just before you want it.
You can just press the minus button on the steering wheel to reduce the set speed fractionally.
Mine is probably similar, think it sets when I hit the button. Not far off. I’ll try and check next time I’m out.
I have adaptive cruise, so it varies sometimes anyway.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #571140 28th Oct 2020 2:26pm
mjdronfield
Just realised you have an L405... oops.... probably different software to mine then.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #571142 28th Oct 2020 2:53pm
no its the same....
its no big problem, as above, set and adjust using the minus and plus.... ... - .- -.
Post #571144 28th Oct 2020 2:59pm
goodeone
Many thanks for the reply’s, It’s not a problem, I can adjust as you say but is this just a quirk of Range Rovers? Every other car I’ve owned has traveled at the speed set, not 1mph above it, the centre of the dashboard tells me I’ve set the cruise control at 70mph then the digital speedo shows 71mph. I thought there might be some kind of calibration I could preform to get them to match.
Post #571151 28th Oct 2020 3:54pm
