Home > Maintenance & Mods (L322) > Second Battery Install
dan_uk_1984
Been wanting to fit an Axillary battery for some time. not for any specific need or reason. Just as a proof of concept really.
I'm still waiting for various cables and connectors to turn up from eBay, but the battery itself is in and ready to hook up. I've put it on a rubber mat to stop it moving around and also to catch any acid spill, although I don't think this will be an issue.
As for hydrogen gas given off whilst charging, directly above is the forced air ventilation system which extracts air so this should remain fairly well vented at all times.
As for linking it in, there is already a 100Amp cable in this area I intend to use with a 40A maxi fuse in-line to ensure absolute integrity of existing vehicle wiring. I think initially it will just be an additional battery, rather than having a split charge/relay system. So I will just get extra capacity rather than redundancy.
When installed and the floor is back on, you cant tell it's there:
Range Rover L322 Dual Aux Battery by d86cfv, on Flickr
Post #61342 23rd Apr 2011 9:02pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Where are you going to mount the fire extinguisher?
Post #61360 24th Apr 2011 1:03am
mzplcg
Hey Dan. Yup I tried this when I moved to a full fat from a D3. The D3 has 2 battery trays under the bonnet and it's very useful for things like Engel fridges. Basically it preserves your starting battery.
But, in the FFRR you only have a 100a cable if you tap into the big red one just above where you put the battery so unless you split charge it it A: Won't preserve your main battery, and B: You won't get enough current up that cable to start the engine.
Point B is the important one though. If, for any reason, you happen to end up with a flat main battery, unless it is split charged there is the possiility that the engine will try to pull massive currents through that 100a cable during starting. Could get rather hot. Whistle Best solution is to use a large (200a) relay to isolate it when the engine is not running. Got some bits in the garage if any use to you - will do exactly that.
I tried an Optima yellow top, mainly because it was a sealed gel type so gassing wouldn't have been an issue. It fitted well but the reality was that it was just another few kilos in the car. No perceivable benefit and it was taking up the space where the towbar gets stored.
Interested to know what you might use it for though.
Dom
Post #61365 24th Apr 2011 8:11am
dan_uk_1984
I could suggest somewhere.
Post #61367 24th Apr 2011 8:55am
dan_uk_1984
Dom,
Initially it will just be extra capacity, the battery that's in there is about 50% of the power of the main battery. I bought a gel battery but unfortunately was a smidge too big to fit in the hole, I think Optima's are too big too Sad
I'm aware of the 100Amp cable limitation, thats why there will be an inline fuse rated to 40A and I'll see how often it blows. In reality, it just means I can run the preheater that little bit longer, or forget to turn the lights off or longer etc. As instead of discharging the main battery 50% and then not being able to start, it will discharge only about 75% and should still have enough power to start the car.
Obviously as you say it's not isolated so if I left the lights on for 24 hours then they will both be flat and I'll still need a jump.
The other consideration is installing a relay and running accessories off of the battery like a coolbox or CarPC in standby etc. But this is a low down the list requirement for me - I would settle for a little more resilience, rather than getting a flat battery after a few hours of detailing with the radio on etc.
The main reason I've done this is because I've only seen one other aux battery install and that was on RR.Net by a guy in the US.
Post #61368 24th Apr 2011 9:05am
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Nice Dan, thanks for sharing.
I intend to do a similar install, but with the split charge system and relay in addition to a big fuse ( I am thinking 60A), cos I want the additional battery for fridge, plus the split charge system so I can connect my trailer (with 2x 105ah) to the same system, so the cable from the front of the vehicle would only ever charge the dual battery, and the split charge system would not allow them to operate in parallel.
How I will get this past LRSA is another worry - I have been trying to get info on the dual battery system from the armoured RR from them in the hope that they would approve fitment of a genuine accessory, but to no avail
Please post updates as you progress
Post #61376 24th Apr 2011 12:11pm
mzplcg
Baben, take a look here. Specifically made for LR vehicles. Got a very good reputation on the D3 site as well.
Dom.
http://www.traxide.com.au/SC80.html
Post #61387 24th Apr 2011 3:23pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
It does, of course, mean you'll have a reasonable amount of spare amps to power your winch...
Very Happy Not sure you should be reading this bit.
Post #61396 24th Apr 2011 7:34pm
speedymarktd6
im keen on this one aswell and i have been thinking similar thaughts i.e
-gel type battery
-IBS split charge
-1000w ac inverter
to run a small kettle and fridge and other small electrical items
keep up the good work and research
Thumbs Up onto no6 Range Rover
Everyone needs a hobby
Post #61397 24th Apr 2011 7:35pm
Baben
Thanks Dom, that traxide looks very simple and easy
Post #61502 25th Apr 2011 4:09pm
dan_uk_1984
Finished the install today.
For a basic install like mine you will need:
    Battery (no more than 7 inches wide and 7 high, length is less important but this one is 9.5 inches)
    Battery terminals - I chose these No Spark/quick release ones.
    Cable - I bought a cheap set of 100Amp jump leads as this was the most economical way of buying the cable.
    Maxi Blade Inline Fuse Holder - Again, eBay
    Misc crimp connectors, depending on your setup. I used a copuple of ring crimps as that seems to be the factory style.
Finished article:
29042011428 by d86cfv, on Flickr
So far no warnings etc, but tomorrow morning I will run the FBH for its full burn and measure the voltage throughout. Without the extra battery it was cutting out at 11.4V around 15-20 mins unless I'd been on a long run the day before as my battery is fairly naff.
This really is just a proof of concept to ensure that the charging system and vehicle electrics are up to the job of running a second battery. My only doubt was the sensitive charging system, however this seems to manage the situation just fine. I will report back next weekend after I've used the car for a weeks worth of short journeys.
Post #62139 29th Apr 2011 8:00pm
daveo
nice one dan, looks like it was out of the factory with it.. have you had a chance to see if you get low voltage warnings come up when do a scan V8 facelift Range Rover Autobiography 22" wheels.
Post #62150 29th Apr 2011 8:55pm
dan_uk_1984
I'll have a scan after a week or so, see if anything comes up. I've been getting HDC inactive recently, due to low voltage I believe.
Not had that message at all today. Thumbs Up
Post #62152 29th Apr 2011 9:13pm
Turbo Tony
Dan, what's holding the battery secure?
Is there a clamping mechanism of some sort?
If I have battery issues with the FF I get, this is definitely an option I'd be looking at. Researching my first Range Rover purchase
Post #62214 30th Apr 2011 1:30pm
Rambles
Dan
any update? Glad to see people are keen to see full use out of the FBH. If you have no problems, I think I might do this mod myself too.
Post #62358 2nd May 2011 7:37am
