Home > Technical (L322) > Front Wipers
Mousey
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Front Wipers
Hello everyone,
Had a novel fault started the other day, as I was driving in slight rain with my front wipers on in position 2, continual slow speed, they suddenly stopped at about 1.00 o'clock position on the screen I moved control into fast and they re-started.
When I run with the wipers in slow continual the fault re-occurs after about 2 or 3 minutes but always clears with change to fast or intermittent position.
They always stop at the same point on the screen!
Any ideas please.
Mousey
Post #570641 22nd Oct 2020 11:31am
Pawl
Its possible the contacts in your wiper switch are greased up or breaking up.
I had similar problems on our Discovery 2, cured by replacing the switch with another second hand one.
When I took the faulty switch apart I found it had a surprising amount of grease inside it & when all cleaned off it worked OK again. Paul,
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Post #570662 22nd Oct 2020 2:53pm
Mousey
Hi, are you talking about the switch on the column or the contacts on the wiper motor?
Cheers
Mousey
Post #570679 22nd Oct 2020 6:12pm
Pawl
The colulm switch. Paul,
Post #570683 22nd Oct 2020 6:29pm
Mousey
How can the column switch stop the blades in the same spot every time it happens? could understand if it was a motor issue!
Mousey
Post #570694 22nd Oct 2020 8:34pm
