![]() | Home > Wheels & Tyres > 275/45/20 tyres on SVD8 L405 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7978 ![]() ![]() ![]() |
They would be shorter than standard by 1" diameter, so the car would sit 1/2" lower.
FFRR64Royal Member Since: 18 Jul 2020 Location: Saltash Posts: 130 ![]() ![]() ![]() |
Thanks for the tips Alistair |
Alistair, could I utilise your knowledge once again with a secondary question?
Sorry - no idea.
Thanks for the reply and the link Alistair, the link has provided so much great info |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
Your 20" rims in the picture are marked 8.5J X 20 ...et47. which means that the rim width is 8.5 inches (8.5J) and the offset in mm is 47.
Seatown.....your description makes perfect sense, and now I can actually see the numbers and make sense of them.
There is a tolerance in the wheel width - it somewhat depends how straight you want the sidewall - there are benefits to a slightly narrower wheel in terms of protection.
Thanks for the info Alistair and for the link:
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3767 ![]() ![]() |
Yes they will fit fine - I have a set of 285/50/20 on the same wheels - so your size will be fine 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
275/45/20 are too small for an L405, they are fine for an L322 though. Personally I would (and have) go for 285/50/20, I am also sure Emperor Mong on here used to have a set of 285/50/20 Cooper LTZ’s on a FFRR - a search should find it
