![]() | Home > Maintenance & Mods (L322) > Rich and lean idling? |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 ![]() ![]() ![]() |
Perhaps "glow" was the wrong word to use. What I meant is at about 2.2 gallons the indicator will flicker depending on how the fuel is moving around the tank - i.e. when going up or down hills or side to side around bends. Full permanent Illumination should occur at 2 gallons remaining leaving little margin. I really wouldn't chance running any modern car until the warning light comes on risking running the tank dry as this can cause damage to the fuel pump and engine systems even causing engine misfires and other fuelling issues as well as damage to the cat. Give the old girl a good drink and reset the trip - you may get more reliable readout in future ......... maybe?? |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Yea I must stress this was the exception not the rule I don’t go that low normally - but my BMW as it is lpg converted and uses very little petrol I only ever have about 40miles in it and been that way for 9 years never an issue ran that right to zero in an emergency still was fine. Current stable:
