Home > Wheels & Tyres > Up a size?
bear100
Up a size?
Hi
That dreaded time has come for a new set of tyres for the front Big Cry again Big Cry 4 years old 28k miles and now the 3rd set of tyres Big Cry
they are 275/40 22's Conti LX sport
Can i change them to a 275/50? to give that extra bit cushion? i find these very harsh on our lovely roads Rolling with laughter 2010 defender utility
2010 RRS TDV8 (gone)
2007 discovery 3 (gone)
2004 discovery 4 (gone)
1994 discovery 1
1970 v8 hybrid (gone)
1975 bobtail (gone)
Post #570018 16th Oct 2020 3:34pm
dolph34
Just from what I have read , 40 is the biggest you can go but 285 40 22 fits fine 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #570041 16th Oct 2020 5:12pm
bear100
Theres a shame i was hoping for a little extra rubber
Thumbs Up 2010 defender utility
1994 discovery 1
1975 bobtail (gone)
Post #570045 16th Oct 2020 5:33pm
dolph34
The 285 40 22 will give a bit more sidewall 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #570048 16th Oct 2020 5:51pm
Vogue
This ^ and the spare will fit in the boot well / I can confirm from personal experience 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #570055 16th Oct 2020 6:30pm
Mr Tee
That’s quite a lot of tyres over a short period, have you had the tracking done?
Post #570102 17th Oct 2020 8:10am
Plenty of options for extra rubber, but it means smaller wheels.
However, you can often pick up sets of wheels & tyres for not much more than the cost of the tyres - and once you've sold your old wheels, can even be up on the deal.
Post #570112 17th Oct 2020 9:59am
bear100
ive had the tracking done and it was not far off tbh, always the outside edge that wears the rest of the tyre has lots more tread Shocked
A 285 will give a bit more side wall Very Happy only changing the fronts for now would this be an issue having a slightly larger on the front?
ive though about going down a size but my wheels are in really good order and look nice, something to think about
thanks for the replies
1994 discovery 1
1975 bobtail (gone)
Post #570114 17th Oct 2020 10:55am
CUE99T
Just sounds like you drive it like Alistair and me....like a sports car....lol
I often get the wear on the outers....and I have read you shouldnbt swap them back to front....but I do.....and I was thinking of a set of 21's also as the ride quality is quite softer but the double twos just look better......lots of ebay tbh! all smug in my new plug!
2021 Westminster Black D300
2013 Vogue SE - gone
Some Porsche Cayenne guff pretending to be a 4x4!!
2006 Vogue
2004 Vogue
2001 Vogue
Post #570120 17th Oct 2020 12:16pm
CUE99T
not really its just wider.....still needs to be same size as rear......unless you change all 4.....
I think you'll need to go down to 21's if you want a 45 or more profile.....
I had been told in the past that the profile is kinda predetermined and needs to match the wheel size diameter...not so much the rim width....as Craig has 285 I think on his 23" but Khan suggest 305....so its obviously ok to alter the width a bit but diameter not so much.
Keen to see what you do.....I'm kinda there too.... all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #570121 17th Oct 2020 12:22pm
dolph34
A 285 40 22 will give you a 4mm taller side wall over a 275 40 22 side wall. Obviously not huge but an increase none the less. Smaller wheels are an option if you are happy with the aesthetics and the handling. Personally I prefer the look of 22s and the more positive feel handling wise but each to their own in both departments. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #570124 17th Oct 2020 1:03pm
Big Boy R44ROV
Change to Pirellis. The Conti's wear just by looking at them! Tony
You're always in the Censored ........it's just the depth that varies
2014 L494 5.0 S/C AB Silver
2014 L494 3.0 HSE in Chilli
2014 SL63 AMG White
Gone:
2011 5.0 L322 White (Stolen)
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
Post #570125 17th Oct 2020 1:43pm
CUE99T
dont get that......can you explain? all smug in my new plug!
2006 Vogue
2004 Vogue
2001 Vogue
Post #570141 17th Oct 2020 7:26pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
If memory serves me right the sidewall is calculated as a percentage of the tyre width?
Ie 285 40 the sidewall size is 40% of 285mm = 114mm
Ie 275 40 the sidewall size is 40% of 275mm = 110mm
Dave 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #570143 17th Oct 2020 7:44pm
dolph34
The 285 part of the 285 40 22 is the width in millimeters the 30 is the aspect ratio ( percentage ) of that width and the 22 is the diameter, so a 275 40 22 tyre would be 275 mm wide with a 110 mm sidewall and a rim size of 22 inch. A 285 40 22 would be 285 wide with a 114 mm sidewall and a rim size of 22. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #570144 17th Oct 2020 7:45pm
